Question on wheel shims?
Old May 23, 2004 | 12:39 AM
Srigs's Avatar
Question Question on wheel shims?
I did a front brake job and my drivers side wheel did not have a shim but my passenger side did. Two questions:
1. Is this normal?
2. Should there be a shim on both?
Here is the part number from it 4863760.
Thank you in advance. Srigs
Old May 23, 2004 | 05:53 AM
amartinson's Avatar
I can't tell you why it is that way, but I have seen several people ask the exact same question, so I guess it is common and normal.
Old May 23, 2004 | 08:29 AM
infidel's Avatar
The shim is only used on one side.
The shim was a band-aid type fix Dodge did to prevent pull to one side. Most folks who have removed the shim report it made no difference. Many times the shim will stick to the back of your rim in a tire rotation and end up where it wasn't intended to be, I found one on the rear of a truck once.
Old May 23, 2004 | 10:43 AM
Srigs's Avatar
This is good information to know. It is normal so I will leave it in place.
Note: I don't have any pulling problems now so I will keep it as is. It is about 1/8 inch in thickness.
Forrest Nearing
Off Road / 4x4
Nov 17, 2006 12:00 PM
nightwing695
Apr 12, 2005 08:56 PM
nightwing695
Apr 12, 2005 08:37 PM
kyot
13
Sep 1, 2004 10:22 AM
