Quad door lock
Old Aug 28, 2007 | 11:22 AM
farmer dave's Avatar
Quad door lock
I am having trouble getting one of my quad doors to close well. I looked at the lock on the bottom of the door and noticed that the spring broke that is attached to the small wedge that helps keep the door tight. I called the dealer about it and they said I had to replace the lock and it would cost $70. I was wondering if there is another way to fix the lock.
Thanks,
Dave
Old Sep 7, 2007 | 01:50 PM
Does anyone know about these locks and how to fix them?
Old Sep 7, 2007 | 06:41 PM
madhat's Avatar
Administrator/Jarhead
I don't know, but I'll give you a bump to the top...
Old Sep 7, 2007 | 08:24 PM
Lurch's Avatar
If you take the inner panel off the quad door there is a vent low on the door that you can remove to get at the nuts holding the lock on. Don't just try to remove the bolts from the bottom, they will twist off. When I bought my truck one latch was rusted shut. Had to lay on the ground and run a punch through the little access hole to force it open. Don't know if you'll be able to fix yours or not. Mine was beyond repair. Can't find the link but I got a brand new one for about $60. Quick Ebay search shows $45 for a used 1.
Good luck
Old Sep 9, 2007 | 01:06 PM
JSPulliam21's Avatar
How do you get the door panel off the quad cab rear door?
Old Sep 10, 2007 | 01:05 PM
The panel only has a couple of screws under the door handle and some of those plastice things on the inside. It isn't that hard to take off.
Old Sep 11, 2007 | 06:58 AM
Lurch's Avatar
I trashed all my little "christmas tree" plugs pulling the panel off. Only a couple bucks for a bag of new ones at most any parts store. Also snapped the little plastic retainer piece off the cable for the inside door handle. In my truck nobody rides in the back anyway so it wasn't an issue.
Old Mar 18, 2008 | 01:18 PM
RenegadeT's Avatar
Good luck
Any more details on this access hole? I tore my door apart from the inside and have determined the lower latch is rusted/broken/fused shut. I'm pretty sure the access hole you describe is where I shot half a can of PBlaster. So I just slide a 3/32" or so punch in there and knock something open?
Hook me up, I searched instead of creating a new post
Old Mar 18, 2008 | 02:08 PM
Lurch's Avatar
I'm assuming your other door is functional. Open it and take a look at the latch mechanism. This will give you a better idea what you're beating on.
Old Apr 9, 2008 | 10:54 AM
RenegadeT's Avatar
I tried opening the functional passenger side door thru the access hole, but couldnt get it. Any more tips on what to beat on?
Dynocon
Mar 4, 2008 08:32 PM
staarma
0
Oct 25, 2007 12:49 PM
xp8103
Jun 2, 2006 07:00 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
