PS pump and fluid problems.
I have been having alot of problems with my PS pump. Im on my second one and both of them seems to keep leaking where the pump goes into the reservior (I do have the hydroboost). Also i noticed in my pump when i take the fill cap off, the fluid is sometimes creamy light brown color, sometimes its normal color. And another concern i have is the other day i took my master cylinder cover off and my brake fluid was black! Im not sure what that means but im sure it isnt good. Anyone have any thoughts on this?
hi
i think where the pump goes into thr reservior is a large o ring around the pump body , easy replacement .
the fluid being milky is prob air in the fluid , when you pull the dip stick lay it on a clean dry surface and look to see if the fluid is full of tiney air bubbles that disapate in a few minutes .
low fluid level can cause this .
LockedandLoaded
01-17-2008 02:51 PM
Tommy93w350
06-26-2007 04:42 PM
icrider
09-27-2006 03:10 PM
