PS/Hydroboost HELP!
Old Sep 29, 2013 | 09:12 PM
mannytheman's Avatar
PS/Hydroboost HELP!
2001 2500 5spd
I lost powersterring and power brakes a few days ago and since the PS pump was leaking I decided to start with that, i also rebuilt the vac pump wile I was at it.
Im pretty sure I bleed out all the air.
Now I can drive the truck for about 10min and then my brakes get rock hard and I can bearly get the truck home, I still have powersterring but not full range...maybe 1/2 turn side to side.
Any way to make sure it's my hydro and not just air...or maybe the master???
Realy don't want to spend $600 and not fix it.
Thanks for any help
Old Sep 29, 2013 | 09:44 PM
BigIron70's Avatar
Cummins Guru
You did fill the power steering reservoir with the gold power steering fluid and not use the red type or ATF, Right?
You could have a defective pump, you need a power steering pump pressure tester. Most shops have them and only takes a few minutes to hook one up.
All With Hydraulic Booster following pressure reading
PSI reading of 1450 to 1550
GPM of 3.1 to 3.5
Old Sep 29, 2013 | 11:27 PM
Thanks
I just used regular gold colur PS fluid
I did just read another thread about a guy having similar issues and it turned out it was a bad pump, so I'll get me pressure checked...thats a good idea.
jarvis243
Sep 18, 2012 09:10 PM
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
CrewCabCummins
Sep 7, 2004 09:51 AM
