Help! New hydroboost and now no brakes!?
Old Sep 15, 2012 | 05:08 AM
jarvis243's Avatar
So i replaced the hydroboost on my 2001 ram and i cycled the steering both with the truck running and not running. Now my brake pedal goes to floor with zero resistance and will not return on its own at all. I did not undo any of the brake lines when i did the switch i don't think that i caused any air to get into the lines. What could be the problem? Could it be a bad hydroboost or a bad mastercylinder? Is there a way to test them? Please help. Thank you for the replys.
Old Sep 15, 2012 | 06:37 PM
gorms's Avatar
How about with the truck not running? If you can put the pedal down pretty easy with it off I'd imagine the master is no good. I do recall some time back someone had a similar experience and it was a bad hydroboost though. Good luck.
Old Sep 18, 2012 | 09:10 PM
richard's Avatar
There is a diaphragm or something that you have to take from your old hydroboost unit and put in your new unit or the pedal will go to the floor. I had the same issue when I replaced mine. Just don't remember exactly what the part was.
thechoochlyman
Oct 26, 2016 04:15 PM
steven.m.coon
Aug 30, 2012 10:54 AM
Superduty
Dec 18, 2005 02:45 AM
apache
Jul 10, 2005 03:14 PM
