Hydroboost for brakes
Old Jul 10, 2005 | 12:33 PM
apache's Avatar
I was talking with my neighbor and he had told me his vac pump went south long ago on his 94 and he converted his brakes to Hydroboost. Hows this work? I know GMC uses this on their gas trucks, but I can pitcure the set up.??
Old Jul 10, 2005 | 01:07 PM
rockwithjason's Avatar
The hydroboost uses oil pumped from the power steering pump to operate the power assist unit for the master cylinder. This conversion has been done many times. You will have to find a hydroboost unit that will work on the truck and make up the pressure and return lines for the ps pump.
Old Jul 10, 2005 | 01:31 PM
infidel's Avatar
Only problem with changing over to hydroboost because the vacuum pump is bad is that the brake boost isn't the only thing that operates off vacuum.
Without a funtioning vacuum pump you will lose the HVAC controls and 4wd.
Old Jul 10, 2005 | 02:21 PM
apache's Avatar
Have to ask him on that one reagrding the heater controls. Its a 2wd. Does the oil from the pump turn a vac pump on the hydro set up? I remember on our old 85 GMC the unit was part of the steering column I think??
Old Jul 10, 2005 | 03:14 PM
No, hydroboost is all hydraulic, no vacuum at all. The unit bolts in place of the vacuum booster on the engine side of the fire wall.
thechoochlyman
Oct 26, 2016 04:15 PM
jarvis243
Sep 18, 2012 09:10 PM
steven.m.coon
Aug 30, 2012 10:54 AM
Superduty
Dec 18, 2005 02:45 AM
