Power steering problem
Old Dec 24, 2003 | 07:22 PM
turbo thom's Avatar
The PS pump on the wife's started moaning when it started getting cooler. Then started leaking. I called Ron and ordered the seal kit thinking that would cure the leak. Well I took the truck into our deisel here and it was really leaking now. Jeff said he had never seen a leak out of the pump that bad. I left the truck and had to go back to Savannah for work and called Jeff the day after. Wouldn't you know the the seal was shot , but because the drive tooth was braken off and really made a mess. $780 for a vacuun pump and $60 for a new drive gears and Jeff's labor, the truck was on the road. The bad part is the pump is a Cummins part to Dodge for $ 388.
Story point? Find one cheap, buy it and keep it for a rainy day.
..Preston..
Old Dec 26, 2003 | 01:33 AM
AlpineRAM's Avatar
Good thing is that mine is still tight. No more moaning and groaning in the morning.
AlpineRAM
Old Dec 26, 2003 | 06:37 PM
torquefan's Avatar
The p/s systems on these trucks are real nasty to bleed after they gulp some air. The best way is to fill up the reservoir, then start the truck and shut it down right away. Top it up again, then repeat this until level no longer drops. Then start truck, turn wheel 1/4 turn and shut off. Top up and repeat.
tony99
Apr 9, 2014 08:25 AM
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
ccw55
Dec 5, 2005 03:33 PM
burlhall
May 9, 2005 08:05 PM
