nothing but defrost
Old Feb 15, 2004 | 08:15 AM
deezel's Avatar
nothing but defrost
Turned on heat this morning and noticed legs were getting cold.Tried to get heat to come out on floor but only derost will work . I had thought this year truck no longer used vacuum pump system but it looks like I was mistaken.Brakes are hydraulic boost so what is left for vacuum to operate.
Old Feb 15, 2004 | 08:44 AM
Tfeore's Avatar
I am almost positive that the gate for the directionoal "flapper" (sorry to be so technical) is vacuum. Defrost is the normal postion when you loose vacuum. You can hear the air in my '04 so I thikn yours would be the same.
Old Feb 15, 2004 | 09:01 AM
MnTom's Avatar
Sounds like you lost your vacuum. I guess what I would do is start at the vacuum pump and check the vacuum lines for leaks. Just start at one end or the other and look at all of them. You will probably find a cracked or broken line somewhere. The HVAC systems "default" to the defrost when there is no vacuum.
Tom
Old Feb 15, 2004 | 10:35 AM
BoldtsWagon's Avatar
https://www.dieseltruckresource.com/...threadid=30705
Old Feb 15, 2004 | 10:45 AM
kandgo's Avatar
Check your **** first, as they can and do strip out. I have ran across this before. Goodluck,, Rick
Old Feb 15, 2004 | 11:41 AM
deezel's Avatar
checked vacuum at firewall connector had 27 Hg. .pulled switch out of dash ,checked at switch and had no vacuum.pulled a vacuum with mightyvac at firewall connector going in to switch and it held .now I need to find out whats between firewall connector and dash switch.
Sleigher
Mar 23, 2007 12:23 PM
tradin1
14
Jan 27, 2006 08:46 PM
Rganser
Nov 26, 2004 09:34 PM
