no lights after installing gauges
99 3500 6spdspd
All fuses are good,
Everything worked until we snapped the pillar back up, then nothing, checked fuses and checked for pinched wires
There is also a constant power plug that is now also dead, we were using it for power for the CB,
It looks like place for a relay but there's nothing there in either of our trucks,
Mine is a 2000
All fuses are good,
Mine is a 2000
Thanks, but all of the fuses and relays are good,.
We're checking the headlight switch right now but they are pretty simple and i can't see how it could fail,
Jumping power to the appropriate terminal in the plug gets us lights, but ki think we have a power problem before the switch that is somehow tied into the terminal we were using for CB/constant power
If you didn't blow a fuse and everything worked before you started then about the only other thing it could be is a disconnected or melted wire most likely in the areas where you worked.
My experience is 99% of electrical problems are owner induced.
Yeah i know that, anD i know we caused it, but we've looked around and can't find anything, there was also no smoke or funny smells (other than my brother)
I guess we could check the back of the fuse panel, is there an easy way to do that without being a contortionist
Perhaps you have 2 problems..I seem to remember that there is not much extra wire to those power outlets and I have accidentally pulled the plug off the back before and they are very hard to reach. Did you take power for the lights from the cigaret lighter light? The panel lights are dim-able and controlled by fuse #5 in the interior fuse panel. If you didn't take your light power from there where did you get it and is it dim-able? Do your dash lights work?
