No Headlights!
Old Nov 11, 2007 | 10:44 PM
Brendan's Avatar
No Headlights!
Well not exactly true... I have the daytime running lights, but when I pull the switch for all the lights to come on only the parking lights and dash lights come on, and I can't click on the high beams. For some time now I have had an issue with the light behind the pyro guage flickering and the transmision temp guage has been acting funny, could this all be related?? Or is this as stupid as new bulbs?
Old Nov 11, 2007 | 11:08 PM
displacedtexan's Avatar
My first instinct tells me that your switch is shot. I can't remember for sure but I think that is what happened when the one in my 96 went.
Old Nov 11, 2007 | 11:11 PM
vzdude's Avatar
DTR's 'Go to Guy'
Will the indicator on the dash show the high beams? Could be numerous things......headlight switch, dimmer switch ( multifunction switch ), bulbs, wiring........need to get a test light out and do some checking.
Old Nov 12, 2007 | 11:03 AM
Brendan's Avatar
The high beam indicator light comes on when you hold the switch, but won't stay on. Is there any way to test the switch, or do I have to buy a new one?
Old Nov 16, 2007 | 08:15 PM
Thundercraft's Avatar
Similar problem for me. I discovered today that if I flick the high beams lightly, that I can get the headlights to come on. Hmmm... hopefully come cleaner will fix the problem, otherwise I guess I'll have to buy a new one.
When will Detroit finally learn that if they would build a quality product, that in the long run they would sell more. building things cheap so that they can sell more parts only leads to a frustrated buyer who finally give up & buy another (read foreign) make.
Old Nov 17, 2007 | 01:26 AM
rpausewang's Avatar
I had this happen a few years back. From tilting the steering wheel up and down the wire pulled out of the mutifunction switch. The mutifunction switch is located behind the wheel on the colunm. Remove the plastic cover and detach the switch. I believe the wire was at the top and maybe red on my 2001. Good Luck.
Extreme Diesel
40
Dec 25, 2006 11:23 PM
Hunter
13
Dec 20, 2002 05:59 AM
kingofdodge7131
Dec 14, 2002 02:43 AM
24
Dec 2, 2002 08:19 AM
