New (used) '01- any suggestions?
Old Sep 11, 2005 | 09:52 AM
jrkerns's Avatar
Question New (used) '01- any suggestions?
Hey all,
I'm new to the forum and would like some advice. I just bought an '01 2500 with the 24-valve cummins with 103,000 mi. it has a 354 rear end. is there anything that needs to be looked at immediately or any improvements that can be made for cheap or nothing? Thanks!
Jason
Old Sep 11, 2005 | 09:56 AM
Tayloe08's Avatar
Congrats on your new toy and welcome to DTR. Sorry I don't have any answers to your questions for I am new to this myself.
Old Sep 11, 2005 | 10:06 AM
Dr. Evil's Avatar
Free upgrades...theres really no such thing. You could take the silencer ring out of the turbo if you want to make it louder.
Cycle your key on/off three times ending in the "on" position and watch the odometer window. If there are any codes thrown, they should be displayed. (but not always - for some codes you have to use a scanner)
As well, you NEED a fuel pressure guage. This is extremely important and may save you from replacing the Injector pump (VP-44). At the very leas,t have the post filter fuel pressure checked at idle, cruise, and Wide Open Throttle.
Old Sep 12, 2005 | 03:14 PM
displacedtexan's Avatar
Having a muffler shop cut off your muffler should set you back less than $50.
Drops EGTs and sounds awesome.
Old Sep 12, 2005 | 03:46 PM
dodgediesel4x4's Avatar
You should check to see if it is a 53 block. More than likely it is not, but you will never know until you check, or you see engine coolant all over the pavement via a cracked block...
hitcb1789
May 25, 2010 09:10 AM
BG05TD
21
Oct 26, 2007 04:54 AM
PChouinard
Oct 14, 2007 01:29 PM
