new bumper in progress
Just a plain ole guy
The only issue I see comes from my BIL, who worked at a body shop for years. That thin as Edit bumper may seem flimsy, but it would absorb alot of an impact. Now your frame will bear it all and most likely any ding with any kind of force involved will kill your entire truck. He saw it many many times. Especially with the big pipe bumpers welded directly to the frames.
I rear-ended a car a few years ago in my truck. I had a 3" lift on it at the time. The car was just ruined.. I wound up in his back seat. The only damage I had was some scrapes in the plastic trim under the stock bumper, and it lifted the bumper a little on the mounts which put a crease in the condenser behind it. Think I needed a new grill too. That was cheap.
Looking at the mounts they dont appear to be really strong. But the boxed frame behind them may be. You may want to reinforce the mounts so they dont rotate like mine did. But, make sure they are weaker than the frame, for obvious reasons
If you decide to put liner on something like that, Id pre-treat it with some phosphoric acid to make sure theres no trace of rust or moisture under the coating. That stuff has worked really well for me.
Few progress pics. I welded and ground the ends, and modified the mounts to drop it 5/8" from the head lights. Sanded the surface rust off, and tonight plasma cut the holes for the driving lights. The center hole will get some grating; it's there to allow for some more air to hit the bottom of the radiators. Next: finish welding, grinding, and paint.
wheelndealn
07-20-2006 02:59 PM
