Need Help
Old Mar 15, 2008 | 09:50 PM
Hothead2500's Avatar
Need Help
I went to start my truck today and nothing. The instrument cluster comes on, all the bells and whistles go off, fuel pump engages, and the batteries read 12 volts, but when I go to crank her.... nothing. No click, no nothing. Could it be the igntion switch? Any suggestions would be appreciated!
Ron
Old Mar 15, 2008 | 09:57 PM
MAX340's Avatar
Ron
Check the 20 amp starter relay fuse in the PDC under the hood on the drivers side. I bet its puked. Mine has done that three times this winter, and replacing it takes so little time, that as long as its doing its job by blowing, I'll wait to troubleshoot till its warm.
Old Mar 16, 2008 | 01:25 AM
OUTDOORSMAN's Avatar
Batteries? Passenger side battery takes a puke and the driver side spends it's time making up for it and click! Happened on my 01 last fall. Maybe get them checked at the auto parts store. Good luck!
Old Mar 16, 2008 | 02:49 AM
smokin95's Avatar
Check to see if you have `atleast 12 volts at your starter. your cables could be coroded keeping your starter from getting all of the volts required to start the truck.
Old Mar 16, 2008 | 02:29 PM
I checked the starter soleniod 20 amp fuse and it was blown. Every time I replace it and try to crank her it blows again.
Old Mar 16, 2008 | 03:35 PM
TallTom's Avatar
pull the starter and have it checked at the local rebuild shop. Pay close attention to the cables going to the starter look for burned areas where they might have gotten shorted out.
Change the starter contacts to the heavy duty ones and thats one chore you won't have to worry about for several miles.
TallTom
Old Mar 16, 2008 | 03:48 PM
TallTom
Thanks. It sounds like you might have had this issue before.
Ron
Old Mar 16, 2008 | 04:21 PM
MAX340's Avatar
TallTom
ahhh HA!
Whats the part number on the HD contacts?
Old Mar 16, 2008 | 04:26 PM
TallTom's Avatar
Yep did the cps and about 4 weeks later had to do the starter contacts. Mine would not do anything either. Lesson learned should have checked the contacts while the starter was off doing the cps. The starters have extra tough time in the winter. Below zero temps and oil so thick that it won't run out of the jug and we expect that little starter to turn everything like it is summer. I never had the blowing fuse problem but I read it on here that some have had the hot cable rub a bare spot against the frame and cause your problems. Also have heard of the starters shorting out on the inside.
TallTom
Old Mar 16, 2008 | 05:40 PM
I went ahead and purchased the rebuild kit from ebay, and tommorow i'm going to the dealer to get the upgraded 30amp kit. I let you guys know how it turns out.
Old Mar 16, 2008 | 05:41 PM
TallTom's Avatar
go to the top of the page and hit search, type in starter contacts and it should lead you to several pages and places to purchase them. Use one of the sponsors of this web site. It helps to keep this a free site.
TallTom
Old Mar 16, 2008 | 11:35 PM
Sounds good. I will do that. Thanks alot!
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
