mpg
Old Aug 11, 2014 | 08:34 PM
bigwayne's Avatar
mpg
i was ready some old post on mpg, there is one post that the guy put in a quart of 2 stroke motor oil in with a fill up, does this work with getting better fuel mileage and if so how does it work.
Old Aug 12, 2014 | 09:16 AM
macattack_ga's Avatar
for one, it puts a quart more fuel in the tank.
it also adds lubrication to the fuel which theoretically should improve the longevity of the injectors and pump.
Old Aug 12, 2014 | 11:28 AM
bigwayne's Avatar
Does that help with mpg, I don't kno squat about diesels this is my 1st, I use to put a little marvel in my showerhead for that reason, just lubrication, it did nothing for mpg, is it the same principle?
Old Aug 12, 2014 | 02:44 PM
anoldbiker's Avatar
Reports indicates it help the 2006 and prior diesel engines with lubcity since they went to untra low sulfur diesel. I use it and this is what I found:
* after the first couple of fills the sound of the engine is actually quieter than before.
* as time went by, my mpg increased overall by 1 mpg. but this can be due to driving conditions and style could have change, ect... My friend with a Ford 6.0 said he showed 2 mpg increase. But normally it doesn't increase mpg. Driving habits do.
* it is to lube the fuel since sulfur use to do this and is not in the system present days ( lubes lift pump, injector pump and injectors), and by sound (no instrument but by ear) it got quitier.
Attached is a study done a while back and is a good write up. It might help understand.
File Type: pdf
Old Aug 12, 2014 | 07:51 PM
bigwayne's Avatar
thanks man, that was some good info,i'm figuring out these bad boys alittle at a time
Old Aug 14, 2014 | 09:39 AM
cougar's Avatar
Just an FYI. That is an old study. So the prices have changed and some of the products are no longer available. Though WMO doesn't rate very high, it's free fuel. I wouldn't consider using on my 24 valve though.
bngcustoms
45
Jun 20, 2009 06:55 PM
richard
26
Sep 6, 2007 01:35 PM
bigfish5
Sep 19, 2006 12:56 AM
Maddog
Jan 3, 2003 10:01 AM
rshelton88
15
Dec 22, 2002 09:40 PM
