Looking for some headlight advice.
Old Nov 22, 2009 | 08:15 AM
Hotwheelbill's Avatar
Well like everyone else, my headlights stink! I have read so much on this it ha left me a little confussed.
Can I make any changes for $200 or less that will brighten things up without melting my dash?
Is it worth making the stock lenses work or change them.
Which is cheaper, Sport lights with harness upgrade or Projector lights with harness?
Old Nov 22, 2009 | 09:26 AM
STate's Avatar
I just bought the Anzo lights from Genos Garage http://www.genosgarage.com/prodinfo....r=ANZO-111068C They were real easy to install, only took about 20 min or so. They came with bulbs, and although they are no where near as bright as my old 04.5 lights were, they are WAY better than the stock lights. Another bonus is that you can aim them with a phillips screwdriver instead of a torx like the stock ones. For only $205 for the pair, I think they are a decent upgrade.
Scott
Old Nov 22, 2009 | 09:35 AM
John Faughn's Avatar
There are a number of diagrams for adding relays to your original system , it keeps from heating up the headlite sw. makes lites brighter and if you find good source for parts , could cost around $10 .
The way it works is , getting all the power to the headlites , right from the battery , not going through the headlite sw.
You send $600 on headlite system if you wanted , and about 4 steps between .
Old Nov 22, 2009 | 11:23 AM
CarlJensen's Avatar
No matter what you do the headlight relay system is well worth the time and money. As said, it takes the load off the switch and wiring. Dodge wire systems are notorious for being very light and will just handle stock load when in good condition. Put relays in and polish out the light covers. Makes a pretty noticeable difference.
Old Nov 22, 2009 | 12:44 PM
Doj Dewd's Avatar
i had the same issue - the stockers (non-sport) were junk for light output.
i then installed the LMC harness - don't spend the money on it, it is cheaply made - but it did make a noticeable difference.
i kept the harness installed and went to the popular one-piece housings commonly found on ebay and in the LMC catalogue. the light pattern in these housings was terrible, and while adjustment was very easy, there was only one adjustment screw (can't fine tune it very well). i think these one-piece housings have poor quality control because some guys are thrilled with them while others are very unhappy . . .
the LMC harness started giving me trouble (cheaply built) so i took it out and ran the stock wiring with the one-piece housings.
i then had an accident causing damage to the front end - took a cash settlement with the ins company and upgraded to OEM sport housings and built my own HD relayed harness. i should have spent the money on the sport light upgrade in the first place, i feel it was well worth it.
if i were you (knowing now what i didn't in the beginning) i would do the sport light conversion - no doubt about it. but doing it all at once can be very expensive depending on where you source the parts from. if i were to do it again, i would have just built a sport light harness and kept the non-sport housings. then at a later date i would upgrade the housings when it becomes more budget-wise.
i'm sure you know, the sport lights have 2 bulbs per side and the non-sport only have one per side. a harness built for the sport light conversion will still work fine. all you have to do is add one wire per side (compared to the typical diagrams) and leave the second bulb per side unplugged.
i just gave you a lot of info here, i'll keep an eye on this thread so shoot me some questions . . .
Old Nov 22, 2009 | 12:51 PM
Silver R/T's Avatar
Scott
They sell same exact ones on ebay for lower price. Also add a HID kit to these and you'll be set with a NICE light setup on your truck.
Old Nov 22, 2009 | 06:59 PM
Doj Dewd, thank you for your input as well as the others.
I think Doj Dewd kind of knows where I was going with this.........."Please tell a cheap b******d the way to do it cheap."
This is my route. I will try to post pics and updates as I go. Thanks again.
Old Nov 23, 2009 | 01:50 AM
Russ Roth's Avatar
Originally Posted by Hotwheelbill
Well like everyone else, my headlights stink! I have read so much on this it ha left me a little confused.
Have you tried adjusting them? I did and can see much better down the road. I have no real complaints about mine and they are completely stock.
Old Nov 23, 2009 | 08:57 PM
Steve Roseman's Avatar
I had the same idea, upgrade wiring now and sport headlights later. Do you happen to know which bulbs the sport lights use so a guy would know what to get for the harness?
Old Nov 23, 2009 | 09:09 PM
Dr. Evil's Avatar
Sport headlights use 9004 and 9007 bulbs - 1 in each headlight. Doj Dewd can tell you where to get all the wiring goodies to make your own harness from scratch.
Old Nov 23, 2009 | 09:21 PM
Doj Dewd's Avatar
the sport lights as they come from dodge use 9007 & 9004 bulbs. one of each per side. the 9007's are the outboard bulbs (low beam/high beam) and the 9004 bulbs are inboard (high beam only).
i ordered my sockets from here:
http://www.innovativewiring.com/Part...tPartsPage.htm
Old Nov 24, 2009 | 06:46 AM
That's the same place I was going to order my stuff from, just wanted to make sure I had the right sockets before checkout.
Thanks!
Old Nov 24, 2009 | 10:02 PM
Doj Dewd's Avatar
order with confidence. i did a group by with some local members and he was very easy to deal with.
ask him to throw in some extra terminal pins in case you screw up with your soldering and crimping . . .
mtdoragary
Nov 7, 2013 08:31 AM
89dieselkong
Feb 12, 2010 12:47 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
ryan466
Aug 30, 2006 10:10 AM
jlipskoc
Oct 24, 2005 01:16 PM
