Liquid line replacement woes
Old Apr 23, 2014 | 01:18 PM
Grumptee's Avatar
I've purchased a new refrigerant liquid line but can't figure what sort of tool I need to remove the 'compression' fitting on each end.
See attachment for photo.
What's the proper name for this thing and where do I get the tool to remove/replace it?
Thanks
Marc
Attached Thumbnails Liquid line replacement woes-2002.ram.2500.diesel.ac.liquidline.jpg
Old Apr 23, 2014 | 02:23 PM
sherod's Avatar
Any parts store carries them. May be a set of plastic or metal. I've been using the plastic kind for several years with no problem. Cost is about $10.00.
HTH
Old Apr 23, 2014 | 04:10 PM
gorms's Avatar
Same as a fuel line disconnect tool.
Ditto on the little plastic ones, they seem to fit in tight places better then the folding-sissor type.
For what it's worth, I had problems with that same fitting holding together on the new line. It blew apart right next to my head twice as I was filling it up, NAPA replacements. Make sure it fits perfectly square with nipple it connects to. Even still I had to make a band clamp of sorts to hold the two lines together.
Old Apr 23, 2014 | 05:38 PM
Grumptee's Avatar
Thanks fellas. It was under $10 for a set of plastic release tabs.
Didn't know until the counter man told me that a release is all that's needed.
Marc
Boudreaux
Jun 22, 2011 05:53 AM
JasonblkZ06
Jun 21, 2010 06:31 AM
shortround
Jul 16, 2005 08:30 PM
Stew130
Mar 20, 2004 09:57 PM
Dieseldude4x4
Aug 7, 2003 09:03 PM
