Killer Dowel Pin Question
Old Mar 18, 2011 | 09:15 PM
littlebuddie's Avatar
I have searched around and found no definitive answer as to the latest year that the KDP was a problem in 24 valve Cummins. Some resources say through the year 2001, some say not. My truck was built in July of 1999 and has a Mexican engine block. How do I check if there might be a potential KDP problem with this engine? Thanks in advance for any responses.
Old Mar 18, 2011 | 10:55 PM
torquefan's Avatar
They started phasing in the revised gear housing in the 98 model year. Apparently though, not every engine got the new one. I haven't seen any external markings that would prove whether it's a revised housing or not. To be sure, you need to remove the gear cover and have a look in there. The end of the pin will still be visible, but the hole in the new housing will be necked down on the outside to capture the pin inside.
Old Mar 18, 2011 | 11:04 PM
Thanks torquefan!
Old Mar 19, 2011 | 10:27 PM
torquefan's Avatar
You're welcome. Just keep your fingers crossed that you have the new housing. If not, it's not a big deal to tab it anyway.
Old Mar 20, 2011 | 08:31 AM
fzr400's Avatar
i pulled my cover to check on my 02 built late 01 and there was no visable dowl pin in that location! just solid. i could see dowl pins in other areas. i heard some updated covers were not drilled all the way through to fix the problem which seems to be the case in mine
Old Mar 20, 2011 | 10:00 AM
Copenhagenjunkie's Avatar
Built Jan 1998 and dowel pin was loose, old cover.
rush47
14
Mar 16, 2006 06:55 PM
Abbynormal
Mar 9, 2006 07:53 PM
Abbynormal
16
Mar 8, 2006 09:03 PM
Greguw
Oct 16, 2005 01:25 PM
Holycack
Jun 25, 2003 02:16 PM
