I'm cold help
Old Oct 28, 2006 | 07:41 PM
NGA Ram's Avatar
I'm cold help
My heater is not working at all. I checked the coolant level and it is good, also checked the heater core and it gets hot and coolant still flows in and out. Someone help me before it gets realy cold.
Old Oct 28, 2006 | 07:54 PM
Mopar1973man's Avatar
*** Welcome to the site ***
Now you going to have to fill in your signature so we know what we are working with...
But just for a wild guess you might have a vacuum problem.... Most of all the vent controls are ran on vacuum...
Old Oct 28, 2006 | 10:38 PM
Marine's Avatar
Veteran: Marine Corp
The heater is not working, but you have heat at the heater core.
Do you mean your fan isn't working?
Old Oct 29, 2006 | 12:24 AM
NGA Ram's Avatar
sorry it's a 99. no the fan blows and changes speed but it acts like the **** to turn the temp up isn't working
Old Oct 29, 2006 | 12:26 AM
NGA Ram's Avatar
i pulled my glove box out and when i turn the max AC on the the vent door opens up, but like i said you can turn the temp **** and it never changes temp
Old Oct 29, 2006 | 12:31 AM
Marine's Avatar
So you have heat at the core, but no hot air blows when you have your hand down there with the door open?
I think that the vacuum port has come off, and is not allowing the full flow of the hot coolant through the heater core.
Old Oct 29, 2006 | 12:33 AM
durasmack's Avatar
I believe there are 2 doors on there..... One for the temp control and one for the Max AC function.... Maybe the one isnt moving.... There should be a cable that opens and shuts the temp. vent door... Maybe there is something wrong with it?
Old Oct 29, 2006 | 12:37 AM
Marine's Avatar
All the Max A/C door does is take the air from inside the cab and recirculates it. When the **** is in any other position, it takes fresh air form the outside.
Old Oct 29, 2006 | 08:34 AM
According to the FSM for 2001 Dodge its the blend door that controls the temp.
Originally Posted by From 2001 FSM
TEMPERATURE CONTROL
If the heater outlet air temperature cannot be adjusted with the temperature control **** on the a/c heater control panel, the following could require service:
²
A faulty a/c heater control.
²
A faulty blend door actuator.
²
A faulty, obstructed or improperly installed
blend door.
²
An obstructed cowl air intake.
²
The engine cooling system.
Old Oct 29, 2006 | 09:01 AM
paco72's Avatar
maybe vent door is staying in open position. or valve for fluid is not opening all the way. or engine temp is staying too cool from stuck open thermostat.
Old Oct 29, 2006 | 09:17 AM
There is no control valve on the coolant flow... The heater core get constant flow of coolant. But if the blend door is stuck in the cold postion (which allows the air to bypass the heater core) then you'll get NO HEAT!
Old Oct 29, 2006 | 09:50 AM
NGA Ram's Avatar
well the heater core is very hot too touch and both coolant hoses are hot and about the same temp, the truck temp guage reads about 180. the one door i found is the max ac door where can i find the other one to check it. when i turn the temp **** nothing happens, no sound, almost like it isn't hooked up
Old Oct 29, 2006 | 10:51 AM
paco72's Avatar
if----? the 99 temp *** set up is like 95, the rotating **** moves a cable to move the blend door. look on heater AC housing, maybe clip came off. if blend door, like mopar says, is stuck in cold position you are going to get no heat. removing the heater AC housing would be a real bear.
ollie32
Jul 16, 2009 05:02 PM
akhunter68
Oct 31, 2006 05:07 PM
joel
Jan 22, 2005 08:59 PM
BEHRMAN
Dec 24, 2004 11:05 PM
wings
Nov 8, 2004 05:32 PM
