Idiot lights on, guages not working
Old Feb 26, 2012 | 11:39 AM
usmcwo1's Avatar
2001, automatic trans. All the idiot lights come on and none of the guages are working. odometer reads no buss. Any thoughts? Thanks.
Old Feb 26, 2012 | 11:57 AM
torquefan's Avatar
That can be caused by a module starting to fail, or a connection that just has enough resistance to mess around with the bus voltages. I would suspect that if the modules saw a really low voltage momentatily, even during cranking, that it could cause this. I would start by unplugging the cluster and spraying the terminals with electronic cleaner, then blowing them dry with compressed air and reseating them. Then do a 10 minute battery disconnect and see if it makes a difference.
Old Feb 26, 2012 | 08:33 PM
usmcwo1's Avatar
I will try that, thanks
Old Sep 29, 2012 | 01:04 PM
scottsjeeprolet's Avatar
http://dodgeram.info/tsb/2000/08-05-00.htm
See if this helps
Sleigher
May 4, 2017 02:12 PM
quadstar
Nov 20, 2009 05:23 PM
6speedcowboy
Apr 29, 2006 03:33 AM
cr1998
Jan 4, 2005 12:36 AM
DodgeCowboy
Sep 13, 2003 08:14 PM
