I think my vacuum pump leaking oil
Old Jan 3, 2013 | 03:07 PM
thechoochlyman's Avatar
I think my vacuum pump is leaking oil
I put a 2nd gen vac pump in my truck for a hydroboost conversion...
Long story short, I don't need vacuum for anything, so I just put a black cap over the vacuum port on the pump. I pulled it off earlier today, and some oil started draining out. Is that normal?
EDIT: I accidentally a word in the title
Attached Thumbnails I think my vacuum pump leaking oil-60998_10200192316276265_1554290801_n.jpg
Old Jan 3, 2013 | 05:23 PM
patdaly's Avatar
Strictly a theory, but could it be since the vacuum pump can't pull anything at all, it is sucking oil in? I wouldn't think it would hurt much unless it starts getting past the seal, but I am not sure.
Old Jan 3, 2013 | 05:25 PM
Haven't got a clue about that... next time I start it up I'll take off the cap and see what it does.
Old Jan 3, 2013 | 06:31 PM
infidel's Avatar
Oil would be normal.
The vacuum pump usually has a spring loaded check valve where you put the cap to keep oil from getting in the vacuum system when the engine isn't running.
Old Jan 3, 2013 | 06:32 PM
Awesome, thanks. Is it perfectly fine to run it constantly with that cap over it?
jimbo486
May 8, 2016 06:07 PM
99Silver Bullet
Jan 10, 2008 09:36 PM
BC847
Oct 30, 2006 06:26 PM
yomitch
Apr 21, 2003 06:28 PM
97Dually
Mar 5, 2003 10:46 PM
