HVAC Plenum
HVAC Plenum
I am in the middle of changing cabs from a 00 donor to my 95. I have the cab stripped and am going to change out the heater core and the A/C evap coil and I am wondering if the plenums are the same. If so I will install the new parts in the 00 plenum and use it. I looked up the parts on napa's website and they have the same numbers for the core and coil. I just want to make sure the 00 plenum will work with my 95 dash.
Anyone know if they are the same?
Thanks.
Thanks.
I know of one difference .. that's the blend door actuator. On the 95 it,s cable operated and on the 2000 its electric rotary actuator. You can use the electric one so long as you change the rotary sw over (in the dash). The rest is the same I think...
Thanks for the help,
I am going to use my dash from the 95. I will use the 95 plenum. I just thought I would get that much done and back in before tearing apart the 95 that I have to drive everyday.
TheMighty'67
Jun 6, 2011 05:13 PM
Silver Slug
Feb 14, 2009 01:17 AM
rockittboy
Jan 17, 2006 09:14 AM
