Intake Manifold/Plenum Gasket
Old Feb 8, 2009 | 08:44 PM
Silver Slug's Avatar
I have ran into a problem with the oem intake manifold/plenum gasket(were the manifold bolt to the head). The gasket blows out from high boost levels, I was wondering if anyone has run into this problem and what is a permant fix because the stock gasket will fail. I was thinking of machining the manifold/plenum for a o-ring.
Old Feb 8, 2009 | 10:55 PM
99 24v's Avatar
replace it with a copper one exspensive but will eliminate the problem.
Old Feb 9, 2009 | 05:27 AM
Do you know who sells the copper gasket
Old Feb 9, 2009 | 10:13 PM
Tate's Avatar
Are the surfaces flat and clean? 55 psi shouldn't be popping that gasket out unless teh faces are damaged or the bolts are loose.
Old Feb 10, 2009 | 05:19 AM
97 D-Tec's Avatar
<< thinks the same way as tate. I really wanna know how you go through em like that. i havent lost one except for the 1st time i had to take the intake off it tore.
Old Feb 10, 2009 | 04:46 PM
The gasket was tighten to oem spec and I re checked then when I did the hot re-tq on the head gasket. This is the first time that the gasket failed, the only thing is that I used an aftermarket gasket.
Old Feb 10, 2009 | 08:28 PM
Tate's Avatar
I would go with Cummin's parts when possible.
Old Feb 11, 2009 | 12:32 AM
99 24v's Avatar
had this problem on a 12v with a big set of twins. i got the gasket from enterprise engine. also get the one that goes between the plate and the intake horn at the same time. the only think bad about them was the $$$$.
Old Feb 13, 2009 | 07:52 PM
ok I found the gaskets, cummins part# 3969988, this gasket is for the air heater block and for the air horn. The plenum gasket cummins part # 3947530and this gasket is from an 03 and up, the good thing is that the gasket is metal. Every thining went together good and I do not have any more boost leaks, I was loosing about 5 lbs of boost from the leak.
Old Feb 14, 2009 | 01:17 AM
99 24v's Avatar
thanks for posting the part numbers. might try the metal plenum gasket in the future.
EdmontonCanada
Oct 30, 2014 01:27 PM
TheMighty'67
Jun 6, 2011 05:13 PM
TheMighty'67
May 23, 2011 12:03 AM
Dinner
Feb 27, 2009 09:37 AM
mojo_jumper
Feb 26, 2008 06:03 PM
