Help no dash lights!!!!!!
Old Mar 23, 2004 | 08:10 PM
boughtadodge's Avatar
Hi all I hooked on my fifth wheel tonight and was trying the lights well I had no dash lights so I checked the fuse it was blown so I put in a new fuse and I saw the dash lights come on for an instant and go back off check the fuse and it is good but still no lights. Anyone had any problems with this before??
Old Mar 23, 2004 | 08:26 PM
BigBlue's Avatar
Something is shorting out. Does it blow when you don't have the trailer hooked up?
Old Mar 23, 2004 | 08:41 PM
I have got tail lights and brake lights on the truck and the trailer just no dash lights I don't know when the first fuse blew but the second one never did blow but I still have no lights.
Old Mar 23, 2004 | 09:01 PM
well I am pretty sure it is in my light switch it got dark and I could not check it out. What is the easiest way to get to it.
Old Mar 23, 2004 | 11:09 PM
BigBlue's Avatar
Pull the front dash fascia off (just pops off with a little effort). You'll see the switch and how to remove it. Those switches are notorious for dying.
Old Mar 29, 2004 | 09:25 PM
halerazor's Avatar
i had a similar problem with mine my parking lights went first then my dash lights finally my head lights. pull the switch out and disconnect the harness.mine looked fine on the outside but the connections on the inside were completely melted.if it is the switch go to napa the dealer is way too expensive.
cLAYH
19
Mar 26, 2017 06:47 PM
NoSparkplugs
17
May 17, 2009 10:36 PM
eric13
Oct 17, 2005 07:05 PM
CHarlan
Aug 6, 2003 08:40 PM
