Help!!!
Old Feb 24, 2007 | 04:12 PM
89ranger's Avatar
Help!!!
I have a 99 Dodge 2500 and have a brake issue. The brakes pulsate every time that you hit the brakes. I have replaced the rotors, calipers, and the pads on both sides. Also put a new whel bearing on the drivers side. I took the drums off the back and everything seems to be ok, i took the drums in and had them machined even though the said they were out 6 or 7. What else is there that make the brakes pulsate?
Old Feb 24, 2007 | 04:15 PM
Tate's Avatar
Any ABS lights? ABS will make the pedal pulsate. Does it pulsate evenly regardless of speed, or does it slow down as the truck slows down?
Old Feb 24, 2007 | 04:21 PM
89ranger's Avatar
No lights. The truck shakes at all speeds. really rough at 60 mph but not as rough at lets say 25 or 30 mph.
Old Feb 24, 2007 | 04:30 PM
TIMMY22's Avatar
did you replace the rotors and the calipers at one time? Reason I ask is if you had started by replacing the rotors with a sticky caliper it could quickly warp your new rotors with the heat.
If you then changed your calipers, you would have the problem even though you have fixed the problem. Do you see?
Old Feb 24, 2007 | 04:36 PM
89ranger's Avatar
I replaced everything at once but the passenger side rotor. I then replaced that probably 50 miles after cuz it idn't look bad enough to change but the pulsating still won't go away
Old Feb 24, 2007 | 04:56 PM
John Faughn's Avatar
You might try to find someone with a professional scanner to look at the ABS , flow , codes ect. , it could also be something like the shocks getting old , a flap of rubber inside of one of the brake hoses .
Old Feb 25, 2007 | 05:16 PM
wuecker's Avatar
It could be something a lot easier than ABS. Check the mounting surface behind the new rotors for dirt or rust. Anything that causes the rotor not to be flush will give you a pulsation. Also, check the torquing of the wheels. Are you tightening the lugs in the prescribed star pattern and to the right spec? I've seen these issues come up before(I was a mechanic for 10 years) When the brakes pulsate, is it in the pedal or do you feel the vehicle surge? A surging feeling usually indicates that the rear drums/discs are not true, throught the pedal is the front. I hopew this post helps out.
Old Feb 25, 2007 | 05:39 PM
89ranger's Avatar
Just an update. I put the drums back on after having them turned and the pulsating went away. The guy said one have quite a few spots where the guage was jumping. Thanks everyone for your help
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
