Heater Core Leaking??
I am getting an intermitten fog through my upper vents and my windshield will fog when I turn on my defroster. My windshield will only "defog" if I turn it up full blast (full heat and full fan speed) and wait like 7-10min. Their may be a small hint of antifreeze in the air, but that could also be my mind playing tricks on me.
Does this sound like my heater core is leaking? Could I use an alumiseal or something like that to fix it for a bit?
I am not really losing coolant that I can tell, but this could be a small leak.
Sounds like your heater core to me. I hear that there is a chemical that is similar to the stuff that they use on homes to seal up leaks that is now available for cars. You might want to check it out.
I wouldn't bother messing with sealant. That goes thru your engine. Just replace the heater core. Mine was doing the same thing as you described and a sealant in most cases is just a band aid on a open wound.
It is leaking for a reason and will only get worse.
The stuff I read about was not run through the block. You disconnected the hoses from the heater core and pumped this stuff through (after a good cleaning) and it is sealed. they claimed that it would last at least ten years.
I believe that it was some kind of an epoxy?
Heater Core
I just replaced my heater core. It let go (big time). Around here, Advanced Auto Parts had the best price, $89.00. It has a lifetime warranty and they had them in stock. Replaceing it was somewhat labor intensive....
Take care.
Take care.
Well I bit the bullet and replaced the heater core. It wasn't all that bad. I did it in 8 hours including travel time to advanced for the new part. The saving grace was the swivel ability of the tubes on the new heater core. Otherwise it would have been a major PITA.
Thanks for all of the help everyone.
Paul
Paul
I just did mine a week ago. I just removed the clips off the A/C lines and removed the bolts on the HVAC housing and slid it back, Cut the tubes off the old core and replaced it with a core with swivel tubes. The whole job took me about four hours start to finish. The core cost $200 bucks but I figured it was cheaper than having the A/C serviced and refilled, But when I went to reinstall the drier to the firewall it had rusted and started to leak the oil out of it so maybe I did not save anything after all....................
