Headlight Hi-Beams
Headlight Hi-Beams
I'm having a problem with selecting my hi-beam lights on on 2001 RAM 2500 CDI. When I click the switch the lights flash to high the go back to low or sometimes they go out. If I hold the hi-beam switch on for about 10 seconds then release it the hi-beams stay on and the system works normally.
Is there a headlight relay somewhere? I can't find it. Or is this a problem with the switch itself?
Thanks for your help.
David
David
It is the multifunction switch on the column.
They are available through NAPA, PN DS6142, for about 100 bucks retail. Dodge wanted $288 for the same switch. Hauled them apart, same model numbers inside. Go figure.
Mine did the same thing last spring, swapped out the switch, problem solved.
Good luck
Good luck
Tyeopalinski666
Jan 16, 2014 03:59 PM
handymantim
16
Jul 30, 2012 12:34 PM
vtec_vigor
21
Jun 6, 2010 12:37 AM
mamm7215
19
Jun 4, 2004 09:39 AM
