head light switch flickering
Old Dec 7, 2009 | 12:53 AM
Turbo-Dodge's Avatar
My head light illumination flickers on and off when I go over a bump. Is the light getting burnt out, am I shorting, just started happening. sometimes goes off till I hit dash or another bump.
Old Dec 7, 2009 | 01:51 PM
Beast2B's Avatar
the headlight switch on the dash is notorious for failing. All of the voltage for the lights goes through the switch instead of using a relay to handle the power. The switch will get pretty hot in normal use. Check for melted wires or loose connectors as well
Old Dec 7, 2009 | 04:28 PM
Okay. I only notice it get warm if I'm using my fog lights so I'll check into it
Old Dec 7, 2009 | 05:07 PM
illEatUrDuramax's Avatar
i agree, its most likely the headlight switch. my just went out a few days ago. i had to drive around for a while holding my brights on because none of the headlights would work, even switching to brights didnt work. could be a loose connection tho
Old Dec 8, 2009 | 12:47 PM
took it apart doesn't flicker anymore but, now my fog lights wont come on so i guess i'll have to go to the pick n pull and get a new one
Carl
Oct 6, 2006 05:09 PM
RowJ
May 3, 2005 08:16 AM
Palmetto_kid
Mar 14, 2005 10:07 AM
quantrill88
Mar 11, 2004 08:43 PM
Nuttymopar
Dec 16, 2002 02:48 PM
