Hard Brake Pedal
My truck has always done that. If you pump the pedal too many times you use up all the stored vacuum, and braking is very hard. Rev up the engine a bit to 1500 or so, and you can pump up some vacuum a little more quickly.
-Del
-Del
I dont know about you guys but my truck uses hydroboost power via the power steering pump for the brakes and not the vacuum pump, which is used only for the HVAC vents in the cab. I would think your guys trucks would be the same, just look behind your master cylinder, see if there is a hydrobooster there or a vacuum booster.
Dargo
Jan 12, 2018 07:45 PM
Idaho Guy
Feb 25, 2005 10:01 AM
