Fuel gauge crapped
Old Sep 15, 2010 | 06:23 PM
stonewalldiesel's Avatar
Fuel gauge crapped
Anyone had to change sending unit in the tank on a 2002 SB. Do you have to drop the monster of a tank to change it.
Old Sep 15, 2010 | 06:45 PM
infidel's Avatar
Failed tank sender is very common.
I and many other find it easier to tilt the bed up rather than drop the tank. Don't have to worry about how much fuel is in the tank plus the connections are a lot easier to disconnect when you can see them good.
The dealer mechanics who get paid piecework tilt the bed.
Sender is dealer only and available separately for about $60. Some parts guys will tell you that you have to buy the entire module for $300+.
Not true.
Old Sep 15, 2010 | 07:18 PM
mishkaya's Avatar
I dropped the tank when I had to do mine, but some find it easier to remove the bed. Either way, not too bad a job...
Old Sep 15, 2010 | 08:11 PM
Junk Man's Avatar
I bought a sender from Centroid Products that has no moving parts. They should have the specs since several people have ordered. Not always as accurate as stock but broken stock doesn't work well either.
Old Sep 15, 2010 | 08:18 PM
Thanks guys, I think tilting the box is probably easier than dropping the gynormous tank.
Old Sep 15, 2010 | 08:23 PM
Sending unit was about 100.00 from Dealer Scammers. I called Napa and related parts houses and none of them even had a listing for it so I knew it was OEM only. Well I guess I gotta get dirty again. Wouldn't be the first time with this horse.
Old Sep 16, 2010 | 01:08 AM
Robert Rausch's Avatar
I've dropped the tank twice on mine, and I'll never do it again--next time I'm tilting the bed, aux tank or no aux tank.
Old Sep 16, 2010 | 10:03 AM
infidel's Avatar
To tilt the bed you only need to remove the four bolts on the driver's side, just loosen the pass side.
One medium strong person can tilt it up 18" or so while a wimp props it up with a 2x4.
B.Law
May 4, 2005 09:15 PM
dieslcruisrhead
Mar 1, 2005 02:35 AM
dsljunkie
Feb 9, 2004 03:15 PM
fitzer
Mar 19, 2003 08:51 PM
fitzer
30
Mar 1, 2003 12:32 AM
