5.9 has crapped out!
Old Jan 18, 2003 | 02:33 PM
Monty's Avatar
Re:5.9 has crapped out!
What oil filter have you been running?
Old Jan 18, 2003 | 02:48 PM
Shovelhead's Avatar
Administrator / Scooter Bum
[quote author=OkieBroncRider link=board=4;threadid=9794;start=0#93548 date=1042921991]
[/quote]
You took the words right outta my mouth. :
I'm hoping not a F**M.
Ed
Old Jan 18, 2003 | 03:00 PM
pappyman's Avatar
My words too "F#$M".... ??? its happened before filter breaks down and plugs the piston cooling jets
Old Jan 18, 2003 | 05:52 PM
Shovelhead's Avatar
Keep us posted on the developments.<br>I'd like to know what clogged the cooler nozzles. ???
Old Jan 18, 2003 | 08:53 PM
Dieseldude4x4's Avatar
I thought my luck was bad. That engine was just starting to run good.<br>Let us know what you find out.
Old Jan 19, 2003 | 07:57 AM
PistolWhipt's Avatar
Being a gasser operator for most of my life ... I am ignorant to what a &quot;Piston Cooling Tube / Jet&quot; looks like, where it is and how it works. <br><br> Any diagrams or pictures that you can share to clue me in ?<br><br>I really need to get a Cummins book !!<br><br>PISTOL
Old Jan 19, 2003 | 08:50 AM
Shovelhead's Avatar
The Cummins uses a tube plumbed into the pressurized oil passages to aim a spray of oil under the piston skirt to cool the pistons and prevent meltdown. When these nozzles become clogged, the heat causes the pistons to expand in the bores, causing scuffing and eventual seizure of the piston and your credit limit.
Pic of an piston cooler jet from a UniMog M-B
Old Jan 19, 2003 | 08:29 PM
midwestdually's Avatar
[quote author=Shovelhead link=board=4;threadid=9794;start=0#93753 date=1042987826]<br>and eventual seizure of the piston and your credit limit.<br><br><br>[/quote]<br><br>i like how u slipped that in there.... 8)
Old Jan 19, 2003 | 10:44 PM
DEZLPWR's Avatar
245,000mi on an '01? You must drive a little! Time to buy a new truck or one with less miles.... [undecided] Other things besides your engine are sure to fail soon! :'(
Old Jan 20, 2003 | 02:59 PM
Vaughn MacKenzie's Avatar
fitzer that really bites <br><br>Here's my take on what happened. . . if you are running 1000F post turbo and obviously working it pretty hard, you are probably approaching your EGT limit and have little or no margin of safety. It could be in all the previous times you were close to the limit but not quite there and got away with it, this time you went a bit too far and cooked it. Maybe your EGT gauge has shifted a bit and isn't exactly correct. The fact #6 is the worst and the progressive cylinders aren't as badly damaged tells me it was excessive EGTs that did it in, not anything else such as plugged oil nozzles or filter issues.<br><br>I would definitely run a probe pre-turbo from here on out.<br><br>Have you contacted Piers about a possible shortblock or rebuild? That is probably the first place I would go to if I were in your situation.<br><br>Good luck and keep us posted.<br><br>Vaughn
Old Jan 20, 2003 | 03:35 PM
BoldtsWagon's Avatar
I run post turbo, but I keep the maximum continuous running at less than 850 F. At 1000 post turbo I estimate I would be over 1300.
