Front wheel bearings
Greaseable/Non-Greaseable
They were not designed to be greased after the factory but I found out by accident when I was changing the upper ball joints on both sides. When I removed the drivers side with a puller the hub assembly came apart in two as it is only pressed together. I changed the ball joint and cleaned up the ***** and seats, regreased used the axle nut to press them back together. When I did the other side that same night it came off in one piece so I changed the upper ball joint and just reinstalled the hub. Well the hub that did not come apart and get regreased was the one that dried out a few monthes later and vomited all of the ***** on the road. A tow truck and about $350.00 later I was back on the road. I now purposely leave the 4 bolts on the back of the hub and pull them apart, clean and regrease. Works for me. I will get the kits to change to a changeable bearing when my hubs finally go bad.
Mutt68
Sep 25, 2012 12:51 PM
Wilbur01
Aug 3, 2009 11:16 PM
jetsnow
Sep 10, 2006 12:09 PM
