front brakes lock to easily
Old Feb 26, 2008 | 02:21 PM
smokeyram's Avatar
the front rotors, pads and calipers are new within 5k. on all the ice/sluch lately, the fronts will lock easier than i remeber. causing alot of sliding.
i know my ride has abs only on the rear, and i doubt that even works, starting to doubt my rear brakes even work. but still , shouldnt the grabbing on the front be more gradual ?
Old Feb 26, 2008 | 02:42 PM
xtoyz17's Avatar
Might wanna check the rear brakes. If they're not carrying their weight, the front will lock up easier due to the weight transfer. Some larger rear wheel cylinders will increase braking force, and should help the rears lock before the fronts (and activating the ABS before the fronts lock as well).
HTH,
Shawn
Old Feb 26, 2008 | 06:44 PM
gmctd's Avatar
Pull the inspection covers, check the shoe-drum clearances - should be nearly touching for proper braking hookup - if not, adj the star-wheel (not the one in the Inj Pump, either!)
Old Feb 27, 2008 | 09:29 AM
blackimpala's Avatar
After reading the manual I found that I was doing the automatic rear brake adjust wrong. It says to come to a complete stop each time going FWD and then rev. Works better for me now,
mrbrownmegacab
Off Road / 4x4
17
Mar 29, 2010 07:14 AM
roughstock
Aug 10, 2008 11:51 AM
Dodgezilla
Dec 12, 2007 01:01 PM
04ctd
Jan 13, 2007 09:22 AM
Journier
19
Nov 24, 2004 03:42 AM
