Front Brakes
Old Apr 23, 2003 | 04:45 PM
kingofdodge7131's Avatar
Front Brakes
Hey, first time changing the brake pads. how do i take them apart haha
Old Apr 23, 2003 | 09:44 PM
brassbuldog's Avatar
Re:Front Brakes
Serious? You looking for instructions?
Old Apr 23, 2003 | 09:45 PM
Re:Front Brakes
Or are you just posting to raise your status level? ;D
Old Apr 24, 2003 | 02:53 PM
mymaur's Avatar
Re:Front Brakes
Your kidding, right??
Old Apr 24, 2003 | 08:37 PM
Mr. 45's Avatar
Re:Front Brakes
I take mine apart with tools ;D
Old Apr 24, 2003 | 08:43 PM
geer's Avatar
Re:Front Brakes
I didn't even know they had pads. Maybe thats why mine squeek so bad.
Old Apr 24, 2003 | 10:23 PM
Re:Front Brakes
BRAKES??????...I don't need no stinkin' brakes!!!
Old Apr 25, 2003 | 12:10 AM
BigBlue's Avatar
Re:Front Brakes
Most people use their hands and some tools. The hands are there to hold the tools.
Old Apr 25, 2003 | 02:05 AM
AlpineRAM's Avatar
Re:Front Brakes
You shouldn't take the brake pads apart- but maybe dynamite would work. <br>I usually just change the pads, using tools, hands, feet and some beer. ;D<br><br>Jack up, wheel off, two hex bolts on the inside of the caliper, slide away caliper, throw away old pads, push back piston, put in new pads, slide on caliper, tighten bolts, wheel on, jack down. Voila! ;D<br><br>Clean everything you see after each step. <br><br>HTH<br><br>AlpineRAM
Old Apr 25, 2003 | 06:00 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Front Brakes
Just a small addition to Alpine's post. <br>When you push the caliper piston back, loosen the bleed screw to prevent pushing crud in the lines back into the master cylinder or the ABS control valves.<br>You'll loose a tiny bit of fluid, but save a large repair bill. <br>Also, I like to hose down the rotor with Brakeclean before putting the wheel back on.<br><br>Ed
Old Apr 25, 2003 | 07:53 AM
Joe Diesel's Avatar
Re:Front Brakes
Brakes? I usual stop using a honda civic or anything else thats smaller than me. ;D
Old Apr 25, 2003 | 10:18 PM
CharterBusDriver's Avatar
Re:Front Brakes
Also don't forget to check disk runout and lube caliper pins :
Old Apr 27, 2003 | 02:34 PM
Dieseldude4x4's Avatar
Re:Front Brakes
Don't forget to clean the caliper mounting surfaces upper and lower both on the caliper and the mounting frame on the truck with a wire wheel or piece of sand paper. I wire wheel those surfaces to clean metal and put ever so light a coat of grease on the two surfaces. Helps the calipers slide better.
Idaho Guy
16
Feb 12, 2020 11:15 AM
donsharp1959
Dec 15, 2011 12:40 PM
big jimmy
Jan 29, 2006 11:17 AM
wildcargo
Nov 29, 2005 04:20 AM
