Firewall Question!
Old Oct 29, 2008 | 06:05 PM
leeboy's Avatar
Firewall Question/Fuel Gauge install?
Im puttin in my new Genos garage Fuel pressure gauge. I cant see where i can feed the wires through the firewall. Do i have to drill my own hole, or is there a common plug or something i can pull out and feed the wires through? Im installing the gauge in the dash just below the air bag on/off switch.
Old Oct 29, 2008 | 07:06 PM
98whitelightnin's Avatar
There is a rubber grommet that is right above or close to the steering shaft.
Old Oct 29, 2008 | 08:43 PM
leeboy's Avatar
Whats the best way to route from there over to the place im putting it. When i look through the hole, its all heater stuff. Also, where is people pulling power from? for the gauge?
Old Oct 29, 2008 | 11:51 PM
SIXSLUG's Avatar
Go thru the big grommet on the drivers side just below the cowl, to the right of the brake booster. You can cut a slit in it and run your wires thru it and up and into the a-pillar. Route the egt wires up along the spray skirt along the cowl. Mine started to fall off so I drilled five small holes and zip tied it in place, you can use the zip ties as loops to hold your wiring up out of the way.
Kurt
Old Oct 30, 2008 | 02:04 PM
tx_2500's Avatar
Since your auto you can use the grommet that would be used to run the clutch lines through.
Old Nov 1, 2008 | 11:28 AM
SIXSLUG's Avatar
Yeah, that's where mine go.
gzhel
Jun 18, 2008 07:27 AM
G1625S
Jan 29, 2006 02:02 PM
westcoaster
Dec 1, 2004 12:04 PM
Planetcat
Jun 28, 2004 03:20 PM
clifford
May 12, 2003 10:02 PM
