Final word on Dually Tire Size
Old Mar 12, 2006 | 06:04 PM
blackdiesel's Avatar
Registered
i havent measured it but i got enough space. i usually haul a cord of wood (approx 3 ton) on the back of my truck and the 235's didnt rub. havent loaded it with the 255's tho.
Old Mar 12, 2006 | 07:19 PM
Patrick Campbell's Avatar
I am using 5" offset wheels and put 235s on with some hesitation. There is not much room between the tires. I will have to measure it...
Old Nov 5, 2006 | 08:36 PM
caffecapri's Avatar
Will the jump to 235s:
1. Affect the speedo?
2. Change driving/towing performance based on the effective gear ratio changing from taller tires?
Thanks...
Old Nov 5, 2006 | 10:05 PM
Tate's Avatar
Yes
No.
Mathematically, there is a 4.4% difference (different make and models of tires will be different sizes, even though their numerical sizes are the same) between a 215 anda 235. Its enough that I changed my speedo (with a tuner), but never felt any loss in power with the bigger tires.
Old Nov 6, 2006 | 07:49 AM
JEEPFLEXIN's Avatar
i had a simular experience as CTD NUT, on my 96 the with stock wheels and 235's under a heavy load they would JUST rub (at 80PSI) , i switched to a aftermarket wheel and coulnd probabbly run a 245-255 tire now(the aftermarket wheels space out pretty far) but the 235's fit great. if you run the 235's on stock wheels pump up the pressre if you ar gonna tow/haul. my .02
Old Nov 6, 2006 | 11:08 AM
caper's Avatar
I have a 97 4x4 3500 ant just put 235/85 16 michilin m/s on there no rubbing with a 3000 lbs camper on it
Old Nov 14, 2006 | 04:13 PM
ironman's Avatar
I have 235/85 x16 tires with no rubbing. 3000 lb camper and 8000 lb boat.
Old Nov 15, 2006 | 02:32 AM
1-5-3-6-2-4's Avatar
I've a friend with 2 crewcab dually diesels on 35's.........
maybe368
Mar 27, 2010 03:04 PM
smokeyram
Jul 3, 2009 10:31 PM
dweller
Feb 20, 2007 06:32 PM
DmaxEter
15
Oct 8, 2006 12:22 AM
keithplacervill
Aug 21, 2005 09:26 AM
