emergency brakes
Old Jul 25, 2007 | 08:21 PM
dodgeroper's Avatar
emergency brakes
whenever i adjust my e brake so that it works i get a squealing noise from the rear of the truck for about 2 months and then it will fade as does the effectiveness of the brakes until they don't work at all. Has any one else had this problem. Is it a return spring for the shoes and can i get a stronger one.
Old Jul 25, 2007 | 08:25 PM
Homestead's Avatar
Have you ever pulled the wheels off and looked to see what's wrong?
Jeff
Old Jul 26, 2007 | 04:21 PM
SIXSLUG's Avatar
How are you adjusting your e-brake? Tightening the nut on the cable is not the correct method, that is only to adjust the slack out of the cables. The correct method is to jack up the rear of the truck, support with jackstands and spin the star nuts on the adjustment spreaders while turning the tire. When you feel dragging on the tire back off one or two clicks. Turn DOWN to tighten on the passenger side, UP for the drivers side. Kurt
Old Aug 1, 2007 | 03:43 PM
dodgeroper's Avatar
thanks guys I've done both everything looks good when i take the rotors off n and yes i Know how to adjust my brakes.
SORTIE
Oct 10, 2012 03:11 PM
amercier4
May 11, 2009 05:46 PM
2500Ram
Jan 22, 2008 05:49 PM
wildcargo
Nov 29, 2005 04:20 AM
