Electrical problems
I have to replace my multi function switch. Does anyone know how to remove the tilt steering lever? Secondly, my parking brake light has become illuminated in the dash cluster since last Friday evening. My brakes seem to be operating as normal as ever, however I did notice the light go off once and my speedo started to jump around then went back to normal and the light came back on. Does this that the rear speed sensor has crapped out and needs replaced or is the ebrake switch gone? All fuses have been replaced just in case, but no change.
Thanks
Thanks
Thanks
Every one I have ever worked on has been threaded in. Wrap a small peice of duct tape around it and gently turn it w/ pliers. It should turn counterclockwise to loosen.
Kurt
Kurt
