DW it's back
DW it's back
Yesterday on my way home I hit a pothole with the left front tire and Death wobble shook my fillings loose. Last spring I installed a thuren adjustable track bar, which is still tight on the frame and axle. As are the other front end components.
Could this just need a proper alignment, or is there something else to try.
I figured to get it aligned after the new coils, shocks and tires were on. The front coils are weak, and I would rather replace them instead of putting spacers on top.
i used to have dw constantly, after all new ball joints and another new track bar its gone. now its back, but only when braking, brand new rotors, so im gonna be replacing the hubs this time. as for coils, if you used the D25's, which are the perfect height, my advice would be a good coat of paint, over the factory powder coat.
Ya I know what you mean with the d 25 red paint. I might go with some coils from a spring shop. There was a thread here about 6 months ago where a member bought some quality coils, I cant remember his name but will find it on a archive search.
My rotors are new, and I am kinda leaning towards what wcbcruzer said about the alignment not being correct, and not just within specs.
Well here is the link to my alignment thread. There's links and specs you might want to go by. If everything in your suspension is good and you still have DW, then the alignment should take care of it. Almost anything that's worn up front can cause DW.
https://www.dieseltruckresource.com/...ight=alignment
07Dually
Mar 9, 2007 12:25 PM
Jordan5687
33
Feb 16, 2007 12:37 AM
JoshPeters
Apr 3, 2005 08:13 AM
Rumbles
May 24, 2004 02:26 PM
