Driver side Fender fix?
Old Feb 8, 2006 | 08:48 PM
running4bhs's Avatar
Today I was coming down the Mountain on the dirt road that was 9 feet wide, came around a blind corner and was hit by a dump truck. I want to pull the finder off and tap the dint then sand the yellow paint (my truck is green) and use some primer. I will paint it later on so do you guys have any suggestions or tips on this job for me, or the primer that I should use? Thanks guys
Old Feb 8, 2006 | 11:32 PM
rockwithjason's Avatar
most haynes manuals have a quick and dirty guide to these kinds of repairs. check it out
Old Feb 9, 2006 | 06:57 AM
blackdiesel's Avatar
Registered
if its very bad at all replace it, you can get onr for around $100, not worth the time to mess with much
Old Feb 9, 2006 | 07:04 PM
robert chilton's Avatar
Do not primer it only! Primary actually draws in water causing it to rust under the primer. If you go this route you should atleast throw a layer of krylon on top of the primer as a moisture barier. It can always be sanded down later for a real paint job.
penguinman
Mar 30, 2011 04:51 PM
tex23455
Jun 27, 2008 06:44 AM
Original Junior
Sep 29, 2005 03:27 PM
dma251
22
Jun 7, 2004 11:42 PM
atc250r
Aug 26, 2003 08:52 PM
