drive side head lamp very dim
Old Oct 8, 2006 | 12:02 PM
427AC's Avatar
[ This is a 99 quad cab. The driver side headlamp is very dim. I tried a new bulb and took the battery out to check the the grounds and in the process cleaned the battery acid from the area. Any suggestions would be greatly appreciated. By the way the passenger side lamp works great and the high beam bulb works great too. Thanks again.
Old Oct 8, 2006 | 03:08 PM
super62nova's Avatar
Check the body grounds, It sounds like a ground issue
Old Oct 10, 2006 | 08:38 PM
427AC's Avatar
With only one bulb going dim
Do you think this is the case with only one bulb going dim. The high beams both work great. Any other suggestions.
Old Oct 10, 2006 | 09:49 PM
Smkndzl's Avatar
check your grounds , if not , do a voltage drop test across the load. (light)
Old Oct 11, 2006 | 08:20 PM
427AC's Avatar
Here is more to think about
If I turn the high beams on they will not turn off unless I turn the lights off at the switch on the dash. When I turn the lights back on the high beams are off and the drive side light is very dim. Could this be part of the switch in the colum?
Hoss
21
Dec 3, 2016 02:49 PM
NotaHemi
Feb 6, 2014 04:54 PM
84mphcdt
Mar 31, 2009 03:45 PM
kevellis32
Feb 1, 2008 04:14 AM
danalex
Dec 27, 2007 01:39 PM
