Drilling out transfer case shift rod.
Old Apr 29, 2007 | 09:45 PM
fade94's Avatar
Anybody drilled it out before with a hand drill? I need to run some wires up through the rod. I don't have access to a drill press. If you have done it before, post up some hints to keep the hole straight. Only about 4 inches of straight before the rod curves.
Old Apr 30, 2007 | 11:20 AM
SIXSLUG's Avatar
I'd set it up in a vise nice and level and then drill a smaller pilot hole first. Check that the drill is level and build up some wood under it to help keep it level while you drill. A good cordless has a nice flat bottom or you could use a corded drill on its side. A machine shop could probably do this for you perfectly for not much money. Good luck, Kurt
Old Apr 30, 2007 | 11:35 AM
fade94's Avatar
Thanks for the info.
When I got to work I was checking out the maintenance shop. Drill press in the corner will work beautifully.
Old Apr 30, 2007 | 12:36 PM
SIXSLUG's Avatar
That'd be the best way to get it right!
freight train
Nov 25, 2011 09:06 PM
yeolde12valve
Jul 7, 2007 01:04 PM
justdirt
Oct 6, 2004 02:32 PM
Nicholas
Dec 24, 2002 06:02 AM
