transfer case won't shift
Old Jul 7, 2007 | 10:51 AM
yeolde12valve's Avatar
Exclamation transfer case won't shift
so i shifted my transfer case into 4 low the other day and when i put it back in 2wd it wouldn't go as far fwd as it normally does, then i tried to shift through the entire pattern (2hi to 4low) when the shifter got to 4hi it was in the position it was normally in in 4low, but i couldn't get it to go into 4 low.
does anyone have any idea what could be causing this???
Old Jul 7, 2007 | 11:15 AM
Box5's Avatar
the shift rod might have loosened on the adjuster and just slide out of posistion, so the throw of the shifter would be off. Just check the rod that connects the shifter to the t-case under the truck, and on the shifter side there a adjuster nut thing, make sure it's tight, but also make sure it's posistioned to where u get the right shift pattern.
Old Jul 7, 2007 | 12:00 PM
that was exactly it man, thanks
Old Jul 7, 2007 | 01:04 PM
Box5's Avatar
no problem, glad it was somthin easy.
SCCSURF
Dec 9, 2010 11:19 PM
fade94
Apr 30, 2007 12:36 PM
justdirt
Oct 6, 2004 02:32 PM
Nicholas
Dec 24, 2002 06:02 AM
