Difference btw Bosch alternator & Denso
Old Dec 20, 2011 | 03:38 PM
zthatzmanz28's Avatar
I just picked up a Bosch alternator from a 24 valve. It has a plug fitting where the two field posts are my old Denso 12 valve alt.
I hav an external regulator so is it the same connection--just run the field wire from the regulator to any one of the plug pins and ground the other pin??
THANK
Old Dec 21, 2011 | 01:57 PM
If ther irish auto parts place carries a plug, is that all I would need?
Old Dec 21, 2011 | 05:35 PM
snowjoker's Avatar
I put a Leece Neville on my truck... it was alot cheaper than what the OEM alt cost ! and will put out 160 amps and im guessing thats hot amps.. its almost double the size of the case on the OEM alt..
Old Dec 21, 2011 | 08:56 PM
THe new bosch was $50 so I went with that. I hear the "plug" will work like the studs once I get the wires connected..
VADSLRAM
Dec 10, 2009 10:06 AM
wally5096
May 12, 2008 09:37 PM
Jim5870
Jul 15, 2006 01:32 AM
russ300h
Apr 10, 2006 06:15 AM
