Cruise speeds up??
Cruise speeds up??
Hey all. I bought my 99 a couple weeks ago and I am ready to go on a long trip next monday and I discovered that the cruise speeds up when set. It does it every time that I have tried to set it. Anyway I searched and found the vacuum leak thing to check but does anyone else have anything else I need to look for. Thanks! Blair
jfpointer, this TSB covers the '89 through '96 trucks. Are you aware if it also covers the '99s? I'll still try it, but am curious if it worked for 2nd gen trucks.
When I press my CC "set" button, I've had times when it will start increasing speed without topping out -- after surging up 15 mph, I had to manually shut off the CC or hit the brake to get control of my speed (it was still climbing). I realize the CC will cause a 1-2 mph increase before settling down -- 15+ mph is not acceptable! Is this one of the symptoms of the acid-hole-in-the-hose problem?
Thanks, Franklin
Thanks, Franklin
Thanks, Franklin
Thanks, Franklin
What you're describing really sounds like the hole in the hose problem, though, if it just keeps climbing like that.
trophystock
Jul 6, 2006 06:28 PM
Zeedaddy
96
Aug 25, 2003 08:00 PM
bcb1962
Jun 24, 2003 10:16 PM
