Cruise Control Out on '98 12v, 160k -
Old Jan 22, 2007 | 04:58 PM
Gpete's Avatar
cruise control went out 2 wks. ago. all fuses seem ok. anyone had a similar problem ?
thanks ... my 1st post here ... been reading for awhile.
Old Jan 22, 2007 | 05:10 PM
phox_mulder's Avatar
Welcome.
Are you haveing any vaccum problems?
Defroster, 4 wheel drive?
phox
Old Jan 22, 2007 | 05:13 PM
Devin_01's Avatar
When my cruise went out on my truck it was a broken wire in the steering colum.
Old Jan 22, 2007 | 05:16 PM
wtmtnterror's Avatar
Try moving your steering wheel up and down, that may help locate the problem. Mine also has the same problem...
Anyone have any tips on repairing this problem?
Old Jan 22, 2007 | 08:37 PM
Dodge@KY1997's Avatar
Maybe the Clockspring. There was a TSB for some years I think.
Old Jan 22, 2007 | 09:27 PM
TxDiesel007's Avatar
need to know, is the truck a 12V or 24v?
if its a 12V check the blue wire under the battery on the driver side, it usually gets acidy and coroded and as a result the cruise fails to function properly... or it could be one loose vaccum wire, zip tie all of them to where they are hooked and ur good to go...
Rick
Old Jan 23, 2007 | 11:50 AM
Gpete's Avatar
it's a 12 valve. no vacuum problems.
i'll check that blue wire/ vacuum wires.
thx
Old Jan 23, 2007 | 08:08 PM
Gpete's Avatar
that blue wire/ vacuum wires look ok. the blue wire is grounded on the body/ good contact.
must be the switch or wire thru steering column ??
any other ideas?
Old Jan 24, 2007 | 06:21 AM
atthepark's Avatar
check servo unit
Pull the driver side battery and get to the speed control unit. Pull the large vac line off the front and check to see if you have any oil in the line. I had oil in mine and when I removed the oil from the servo fitting and vac line, all worked fine. Oil can get in the vac lines from the vac pump if the check valve is missing or not working.
Hope this helps.
Old Jan 24, 2007 | 04:51 PM
atc250r's Avatar
Does the light on the steering wheel turn on when you push the power button?
John
Old Jan 24, 2007 | 05:31 PM
Fred Swanson's Avatar
98 light on the dash. if it doesn't come on, then its either the switch or the clockspring.
Mine was intermitent, then the Airbag light came on, so I knew time to replace clockspring.
All is fine now.
Old Jan 24, 2007 | 06:34 PM
jester1542's Avatar
The cruise didn't work on my 97. Found battery acid had leaked on the cruise bellows and made a hole in it so no vacuum. Might want to do a close visual inspection of the whole control assembly located under the battery.
Old Jan 25, 2007 | 09:29 PM
Gpete's Avatar
Guys,
the dash light does not come on. What is " the CLOCKSPRING" ???
"do a close visual inspection of the whole control assembly located under the battery"
" Pull the large vac line off the front and check to see if you have any oil in the line "
ok, i'll check under battery.
Old Jan 26, 2007 | 05:58 AM
2stroke's Avatar
clockspring... in steering wheel.
Old Jan 26, 2007 | 09:36 AM
infidel's Avatar
When the clockspring breaks it usually goes all the way, never heard of a partial break. Along with no cruise your airbag light will come on and the horn won't work.
