cruise control engagement- lurches
Old Jun 16, 2006 | 11:12 PM
big jimmy's Avatar
Does yours do this?
1)When I put it into cruise it grabs the throttle, over speeding for a few seconds the target speed by a good 5mph. Its a pretty good lurch from what the speed is that you are going/trying to set to- like flooring it for a second.
2)The other thing it does is keeps ADDING speed every time you use the "resume" button. So if you kick off the cruise by braking, then hit resume, it will add about 5mph to the original set speed. Do it again and you are 10 over, etc..
It really is one of those things that makes driving the truck a lot less enjoyable.
It will go to and hold the target speed, but only after that first grab. The resume button thing is a drag all the way around, making it basically useless.
Any ideas?
Thanks,
Big Jimmy
Old Jun 18, 2006 | 05:33 PM
big jimmy's Avatar
Everyones at a BBQ?
Old Jun 18, 2006 | 06:58 PM
GearHd6's Avatar
My truck doesnt have the issues you speak of. If my torque converter has become unlocked due to me lifting off the throttle or hitting the brake and then I hit resume it'll punch the throttle and the converter will lock kinda hard but it wont go over my preset speed.
Old Jun 18, 2006 | 09:54 PM
jeff-kc9ftp's Avatar
Mine does the lurch thing, the resume works as it should.
I've read that the cruise module or pcm has a 'learn' feature on some dodge vehicles. By lifting off the accel pedal, even slightly, while engaging cruise will confuse this 'learn' procedure.
The fix was to disconnect the bats to clear the learned data. I haven't tried this yet, my 'lurch' isn't real bad. So, I can't say for sure if it works.
good luck, hope this helps.
Old Jun 18, 2006 | 11:06 PM
Tate's Avatar
Mine does the lurch thing you speak of. After I put on the Smarty, it became worse. Normally, it would pick up speed for about 2 seconds, take the boost to about 15 pounds or so. With the Smarty on, it put it to 35 pounds for about 2 seconds, then backed off completely because it was about 20 km/h over the preset speed. Slowed down to the preset, then punched it again. The guy in the car beside me was giving me dirty looks. I haven't used the cruise since.
Old Jun 19, 2006 | 12:29 AM
tool's Avatar
Yeah my truck does the same thing. Haven't found a sollution yet.
Old Jun 19, 2006 | 01:13 AM
Timmay2's Avatar
I set cruise and the truck doesnt stop acellerating until i hit the brakes..
Seems to be common
Old Jun 19, 2006 | 06:09 AM
mrwaters's Avatar
Same thing here, I always thought it was the cruise taking up slack in the throttle cable.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
seabee_taji
Jan 29, 2009 09:32 AM
MNorby
Aug 29, 2005 06:20 PM
TexasDiesel
Dec 27, 2002 10:47 AM
