cracked dash....
Old Aug 21, 2007 | 09:35 AM
sonnys's Avatar
cracked dash....
I have an 01 dodge cummins 4x4 that has only 70000 miles on it and the dash is cracked in 2 locations is this normal...ALSO THERE IS A SQEAK under the dash as well thats driving me crazy
Old Aug 21, 2007 | 10:57 AM
Tyheethan's Avatar
I too have a 2001 CTD and have the same cracks and squeeks and I think you will see it is somewhat common.
There are replacement "skins" for your dash that some people like whiles others do not. Use the search feature to see what you can find. My choice is to try to find one from a junk yard or even the dealer if necessary.
As for the squeek, I have tried and tried to determine what it is and can't find it. I guess that is why I tell people I drive a CTD and not a Dodge.
Anyone else have any luck finding the squeek?
Old Aug 21, 2007 | 11:15 AM
Busboy's Avatar
It would be interesting to see if all the cracked dashes also have the squeak. Mines a 2001 and dash is in perfect condition (no squeak) however I bought the truck new without air conditioning and I installed it which meant dropping the dash. I'd bet that the loose dash is the cause of the cracking.
Old Aug 21, 2007 | 02:55 PM
deezlfitter's Avatar
I have a 2002 with 100,000 km. The dash is still intact, however it did develop a nasty sqeek that appeared to be from under the dash. After many hours of searching I discovered it was the shifter linkage. Lube it up occasionally and all is well. Hope this helps some of you.
Old Aug 21, 2007 | 08:31 PM
sonnys's Avatar
how and where do you lubricate shift linkage...the transmission linkage or 4x4 linkage?
Old Aug 21, 2007 | 09:06 PM
sonnys's Avatar
Oh did I mention I think I love this truck better than all my other ones!
Old Aug 22, 2007 | 10:22 PM
Just use some good quality lube on all moving parts of the shifter linkage. Usually lasts about 6 months then I have to go through the process again.
NoSparkplugs
17
May 17, 2009 10:36 PM
klx650a2
Apr 20, 2009 05:25 PM
mickey44
Jun 26, 2004 04:01 PM
lawnpro
25
Apr 30, 2004 09:23 AM
WVPANHANDLER
Feb 1, 2003 08:23 PM
