Couple things i need... Point in the right direction?
Although the ram is mint it needs a few parts to make it complete...
*The power door lock switch on drivers side will not "lock" and it also is missing the clip on the front side so it doesn't fit in the door tightly.
*The drivers side power seat doesn't completely work. It goes forward and backward but all the other power adjustments dont work...? Is it a switch? A motor?
*Drivers side headlight fogged inside. Moisture inside looks like CRAP. Need a new one. I would LOVE projectors BUT websites (LMC and such) say that the projectors are NOT for SPORT models. Not sure why?
Thanks and happy St. P. Day!
hi
unplug the seat motor under seat and use a volt meter to see if switch is sending power to it when you actavate switch .
mine was the motor and i had to repair it .
easy way to get to it is remove 4 10 mm bolts that hold cousion on and lift off cousion exposes everything !
Took the seat apart. I am getting power to the plugs. I took apart one motor. Brushes and contact were nasty so i cleaned them up. Still no go... I was getting 12v at the brushes too?!
bngcustoms
Jul 17, 2009 04:53 PM
nasty01cummims
Jun 29, 2009 09:59 PM
Whatever
Feb 14, 2008 06:25 AM
