Cluster lights/Tail lights
Old Jan 31, 2009 | 06:59 PM
Troym61's Avatar
My cluster lights and tail lights are not working, purchased a new headlight switch and still not working, checked the fuses and both are fine, any ideas?
Thanks in advance.
Old Jan 31, 2009 | 09:00 PM
gomopar440's Avatar
Check your plugs going to the headlight switch AND the dimmer wheel. Look for corrosion or melted plastic in the way of the contacts. If either is present, clean the contacts as best as you can and use some di-electric grease to keep it from corroding. Make sure they plugs go back in the sockets tight and then see what you got...
Old Jan 31, 2009 | 09:43 PM
Troym61's Avatar
Thanks,
I will check again, and report back.
Old Feb 1, 2009 | 10:37 AM
Troym61's Avatar
Fellas,
Everything checks out fine, check #5 fuse its fine..... any and all help is greatly appreciated.
Troy
Brighton, CO
Old Feb 1, 2009 | 06:44 PM
Troym61's Avatar
Fixed,
"Quad Lamp" fuse burnt out, odd location for that one....
Old Feb 2, 2009 | 01:03 AM
jnicewan's Avatar
good deal you found it, i almost always check all fuses when im looking for elec problems. this is one reason why i do that.
Old Feb 10, 2009 | 12:09 PM
GBRACER's Avatar
If I may piggy back on this one.
i have a 99 with the instrument lights burning the #5 fuse, if you put a fuse in it will sometimes take up to a few hours to pop the fuse again, I have 3 pillar post gauges hooked in but removed the wire in fear of the circut being overloaded but it still does it.
When a new fuse is installed all the lights work in the dash there are no melted plugs or visable burns.
I am reluctant to but a new head light sw because there is nothing to sugest it is the problem unless the reostat is failing and not showing any signs.
And I am leaving on a 3000 mile trip in three days towing a 30 foot deck with two cars on it and need the lights to check gauges..
HELP!!!!!!!!
Old Feb 11, 2009 | 01:48 PM
powderpriest's Avatar
GBRACER, it sounds like you have a short in that circuit. I had something similar happen when one of my trailer harness wires wore through the insulation. It would ground periodically as I was driving and pop a fuse.
Also had an electronics store install a radio one time and they overwhelmed the relay which took out the dome light and some dash lights as I recall.
Good luck!
Daniel
cLAYH
19
Mar 26, 2017 06:47 PM
Patriot2500
Jun 25, 2008 08:47 PM
rdmartin108
Aug 19, 2007 08:06 PM
CHarlan
Aug 6, 2003 08:40 PM
