Clearance Lights
Old May 18, 2019 | 10:43 PM
99TurboRamMan's Avatar
Clearance Lights
Going to mount some clearance lights on the roof of my 99 Dodge 2500. This is a new install. I know I already have the factory cut outs/ slots on the inside of the cab. Just wondering if for this model year, there is also a factory wiring harness in either the drivers or passengers side door pillars? I thought in the 3rd gens there were, but not sure about the 2nd gens???
Thanks Again!
Old May 19, 2019 | 08:35 AM
I am pretty sure you need the extra cab light wires harness that plug in behind the dash to the rest of the main dash wiring harness.
Old May 19, 2019 | 09:28 AM
Thanks Oliver!
That's what I thought!
Old May 19, 2019 | 10:12 AM
I bet if I don't have one pulled on the shop shelf, I can dig a wire harness up for the cab lights. I have a couple of 2nd gen cab light harnesses on the shelf, I just need to check that they are not just '94-'97 ones.
I know I have the cab light lens themselves too.
Old May 19, 2019 | 11:09 AM
SIXSLUG's Avatar
Could have the prewiring...drivers A pillar. Mine does.
Old May 20, 2019 | 04:22 AM
That's what I was hoping sixslug!
Old Jun 5, 2019 | 11:19 AM
jrs_dodge_diesel's Avatar
I installed a set on my 01 back in 2007. In my truck, nothing was prewired.
Dodge did offer a kit to install them on trucks that did not require them. It included the bulbs, lenses, gaskets, base plates, wire harness, screws and other odds and ends. Even had a template you could tape down on the roof in order to line everything up correctly. Think I paid $90 for it at the time.
There were two kits because there were two sets of lights mounted on top the 2nd gens. The older style was more of a triangular teardrop shape, and the newer ones were lower profile.
The lights are grounded to the roof metal, which simplifies the wiring in that you only needed to run one 12V wire up to the lights. Even if you can't fid the harness, you could make one.
Old Jun 5, 2019 | 02:03 PM
THANKS JRS! Just getting around to it this coming weekend!
Old Jun 6, 2019 | 08:25 AM
AggieJustin's Avatar
Did they revise the lights? I put the lower profile ones onto my truck using a harness from the kit and it still had a dedicated ground wire. The frames of the lights were all plastic, so there was no place to ground. I just ground to a screw that secures the inside edge of my a-pillar.
Old Jun 6, 2019 | 01:00 PM
You know, I'm not so sure now. I did this 12 years ago, and haven't pulled the headliner down since. It may have ground wires that went al the way up too.
I used the older kit because I liked the look of those lenses better than the low profile ones. I'm not sure how Dodge did the kit for the newer ones.
Ramcam
Apr 7, 2007 03:43 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
cummins dsl
22
Jun 27, 2005 11:53 AM
ETurner
Mar 3, 2003 02:43 PM
Nov 23, 2002 07:35 PM
